The passenger side and the drivers side face the same way, on the passenger side they go with the direction you are driving on the drivers side they go against teh direction. Someone told me the dealer gave me 4 of one side.
they did....
though the new Challangers all come that way as well, so the slotted rotors from Chrysler must not be directional..
pretty stupid if you ask me..
read this: http://www.zeckhausen.com/how_to_properly_install_rotors.htm
I always thought the primary function of slots was to scavenge hot gasses from the pad/rotor interface to increase friction and facilitate heat generation (conversion of kinetic energy to thermal energy) and heat dissipation (venting).The slots are there to cut the pads and keep them flat.
My trunk monkey had a litter of baby trunk monkeys so I directed her to have them hang out at the four corners visually inspecting things during hard braking.well, I would like to quickly address something; not to be argumentative, but more to try to clarify. When it's said that the slotted rotors "cut" into the pads, I believe that to be a miss. I completely understand the slots vent gases, and even wear away imperfections that build up on the pad - but to say that it cuts away more material than a non-slotted rotor, I believe, is untrue. When you think about it, the slots are made into an existing flat rotor, hence making the slots not any more abrasive than non-slotted. The slots add an ability to flatten the pads, but not to cut them. Am I mistaken? Hmm... GOOD DAY!
Thanks for the real world testing. I have always wondered at the whole Cryo thing.Lou I hope you have better luck with your cryo treatment than I did. For me, the solution was to just buy cheaper rotors and treat them as a disposable item. My cryo treatment alone ran about $65 and two new SRT rotors were about $125. They crack a little too, but not as much and at that price I don't care.
