I'm in the process of replacing my entire front suspension on my 300 with Pedders bushings. I'm also replacing the shocks/struts and coils with Pedders as well. :modding:
Well, I tried to make my own "pull tool" for removing and installing bushings. It worked pretty well to remove the bushings that were already installed in the new front Upper Control Arms and new Tension Struts, however I ran into major issues pulling the Pedders in. I broke several bolts and stripped several nuts on my homemade tool before giving up. Not to mention in the process one of the Pedders bushings turned out of alignment.
So I called around and found a machine shop at an auto parts store here locally that could take care of this for me. Here they are after they took care of pressing the Pedders bushings in the Upper Control Arms and Tension Struts for me. They even removed the one that turned and pressed it back in at the correct alignment.
Now, next weekend I'll finally be able to tackle the full suspension upgrade. My plan is to remove the front suspension components early Saturday morning and then take the lower control arms (once removed) and the new Pedders bushings up to the shop and have them press out the old bushings and press in the new Pedders. Then obviously I can reinstall everything. I'm so pumped to get this over with.
While they have the LCA putting the bushings in, I'll come back and work on replacing the tie rod ends and installing my bump-steer kit.
