Beans are good... LOL.
After installing it, and going through the TCM "Learn" procedure (You know that the manual says to do 10 minutes of driving without WOT, going from 0-65 lots of times to get the adaptives set?)
Okay.
Spill.
I don't get "odd" torque management bits anymore. the engine always feels like its trying to make as much power as is requested, at all times.
Autostick: Anytime I am under 23-ish MPH, OR, anytime the RPM is below about 1400 rpm, the Torque converter is UNLOCKED. anytime those conditions are NOT met, its LOCKED SOLID. EVEN against the stroker. not a hint of slip. I can be driving 55 mph in 5th gear, go WOT, and my RPM won't change: the engine will bog against the locked trans and try to accelerate. I can slap the stick to the left, get a shift to 4th gear, and it will shift DIRECTLY to 4th, it WILL NOT act like it unlocks (it will nail the 4th gear 1:1 rpm, and not move until the car starts accelerating). Same with 3rd gear. Shifting in autostick is constant, quick, and very reliable. I DID hit Limp mode in 1st gear, but going into limp mode is no longer a "BANG" just kinda... a wimper. I dont' like it. It probably then, means, it has something to do with the ECM. (which ya'll might have known, but I just didn't for some reason).
Shift Hammer now will be a good addition to the car, as autostick is pretty much a stick shift that you don't have to use a clutch.
"D" Drive: Drive is MUCH better. it is "weird" compared to before. The engine does NOT bog when stalling against the converter in first or second, and hooking up anywhere is hard to do. The "Weird" part is: The converter "Locks" in every gear as it drives, but it unlocks on shifting. Accelerating to 55 feels like there is 7 or 8 'shifts' in there. While thats feels weird, it doesn't jolt you around, and everything seems like it SHOULD be there. I have a feeling my 3200+ stall converter is responsible for all the torque converter... behavior... but I am not complaining. My dashhawk says the trans temp never got over 165F.... so... okay, right?
Shift is crisp and a good kick in the butt compared to the other trans computers... I wonder what a B&G with all TM removed would do... probably knock the head rests into the back seat.
MDS in "D" is very odd. It unlocks the converter in 5th gear, but then its like it doesn't know what to do, so it lets 4cyl drive unlocked for a little while. eventually, it locks the converter again and all is good, cruising along is nice. Same thing happens when it kicks out of MDS back into 8cyl. It seems to have been getting better at the transition with more miles.
Shifting from "P" to "R" or "D" is fast, and like it should be in the first place.
Okay. Start asking questions. I'm off to a party so I will answer when I get back. (Can't say the answers will be good tonight, though...)
