Page 1 of 11 123 ... LastLast
Results 1 to 15 of 154
Like Tree3Likes
Thread: LX Thermostat Changeout Video *
    PowerWagon896's Avatar
    PowerWagon896 is offline Clever Disguise as a Responsible Adult
    May 2006
    Waiting on the gravy train
    2 PART VIDEO LINKS FOLLOWS TEXT
    If you are not comfortable with changing to a thermostat (tstat) that has a lower operating temperature range than OEM, read no further.
    tstat change-out
    Changing the tstat can have significant advantages and will eliminate power lose due to heat soak if combined with an effective fan mod. Fan mods such as the “25-cent fan mod” or Jim Turner’s “Got Fan Mod?” will work. Changing the LX tstat is sooooooo easy, but I think some of you would feel more comfortable if you had a pictorial demonstration of this low dollar high benefit “mod”. It is best to do it when the engine is cold.
    It can be done with a warm (NOT HOT) engine as long as you can touch the tstat housing without discomfort. If the engine is warm, relieve the pressure on the cooling system by slowly loosening the filler cap. When ALL pressure has been released, re-tighten the cap before proceeding.
    You will need:
    • 13mm socket
    • medium length extension
    • ratchet
    • medium sized flat blade screw driver
    • 1 gallon zip-lock bag
    • The appropriate thermostat
    Here is a link to Meister's excellent post on alternative tstats
    Alternate thermostats for the LX Hemis - Lx Forums | Dodge Charger Challenger Magnum | SRT8 | Chrysler 300 Forum
    OK you have all the tools, here goes.
    • First, open the hood. You will see the tstat housing to the right (car right, your left as you face the front of the car) and below the intake.
    • DO NOT REMOVE THE FILLER CAP UNTIL YOU ARE DONE AND READY TO REPLACE FLUID!
    • Open the zip-lock bag and place it under the tstat housing, it will lay there if you place it right. Slowly loosen the tstat housing bolts. When the coolant starts to seep out, grab the zip-lock and place it under the housing while jiggling the housing. You should be able to catch most of the coolant and avoid making a mess. Finish removing the housing and place the housing, still attached to the hose, aside.
    • While holding the zip-lock bag under the now exposed tstat, pry out the tstat with the screw driver. Again try to catch the coolant that will leak out.
    • If you have removed the filler cap, hurry up and replace it as you will now lose all of the coolant above the tstat opening!
    • Remove the gasket from the OEM tstat.
    Here is where it can get tricky! If you have the 160* Milodon tstat you can proceed as it is an exact fit to OEM. If you have one of several 170*-180* replacements you will have to try the fit and perhaps file or grind some off of the O.D. to fit.
    OK so you now have the tstat "fit" that you need.
    • Place the gasket onto the new tstat and gently press the tstat into the recess, do not force it. If necessary remove more material from the O.D. to achieve a slight interference fit. Make sure that the tstat is facing the correct way. (it should be marked) Also, if the new tstat has a jiggle pin/bleed hole, position it to the top.
    • Replace the tstat housing
    • NOW you can open the filler cap and replace the coolant you saved in the zip-lock bag.
    • Replace the filler cap, start up the Hemi and check for leaks.
    You're done, have a beer.
    Without a "fan mod" the coolant temperatures will still approach 190*-200*. With the fan mod I was running 165* staging, 175* at the end of the run. This was with the 160* Milodon tstat. This tstat is just a bit low for everyday driving and CAN throw codes during cool weather.
    My coolant temps were running about 190* average on the way home after removing the 25-cent fan mod and replacing the fan relays. The ambient temperatures were about 83* that day. The 160* tstat can be installed @ home and driven to and from the track. It would be best to use some type of fan mod on the way to the track, but wait until the coolant reaches 180*before engaging the fan mod to avoid CELs.
    Click on links below for the videos
    (PART 1)
    (PART 2)
    Immo and gccruzer like this.
    fnkychkn's Avatar
    fnkychkn is offline genuine factory cercumsized sh!tforbrain
    greasy cardboard box
    great video but your BIG popeye arms blocked the view of the ziplock's position catching the coolant.
    Token's Avatar
    Token is online now First AWD LX in the 12's N/A
    Center of the LX Universe
    Good job, nice vid. I especially like the excellent editing, when the front bolt dropped to below and then was magically installed on the back, ready for tightening. BTW..... I did the exact same thing
    12.645@108.18
    May 2006
    Quote Originally Posted by fnkychkn
    I did the best I could positioning the tri-pod. I had it leaning against the front facia with an 8" concrete block under 1 leg.
    May 2006
    Quote Originally Posted by Token
    Shhhhhhhhhhhhhh.
    hemiwagn is online now Converted Chevy Guy
    Oct 2004
    Burlington, Ontario
    There should be a contest to decipher what your tatoo says. Also, I liked the cat meowing at about the 6:12 mark.
    Seriously though, great write-up! Takes all the mystery out of doing this mod. Thanks for taking the time to make it easy for the rest of us.
    2006 Magnum SRT8 "HEMIWAGN"; HalfFast Performance built; OST Dyno tuned; Frank Racing Extreme Heads, Scudd Cam & Ported Intake; Paramount Performance Dominator 4400TC & Valvebody. Best 1/4: 10.898 @ 123.25 MPH, 1.577 60', 3500lbs with driver, DA -595
    Meister's Avatar
    Meister is offline 300C pilot
    Arizona
    Thumbs up
    Excellent instructional video , PowerWagon896. Thanks much for taking the time to put it together.
    It clearly shows just how simple it is to change the tstat in an LX Hemi.
    I've edited post #1 of the Alternate Thermostats thread to include a link to this superb video. As I stated in my update post:
    "This is a "must see" for anyone before your next tstat swap, even if you've done it before.".
    Mega kudos.
    Token's Avatar
    Yup, really nice Powerwagon, such a simple 5 minute job a chimp could do it.
    May 2006
    EASY NOW!
    mikesmagrt's Avatar
    mikesmagrt is offline LX Padiwan
    May 2006
    southern california
    Great Diy Post And Video !!
    Thanks
    2005 magnum rt
    custom c.a.i.
    borla cat back
    hotchkis sway bars
    eibach pro springs
    20"helo wheels
    275/40/20 hankooks
    R1 CONCEPTS DRILLED & SLOTTED ROTORS
    FIBRE EYELIDS
    170 THERMOSTAT
    FLASH PAQ
    Ozzie's Avatar
    Ozzie is offline LX Goo'Roo
    SoCal
    Thanks for taking the time to put this together. You've made this task WAY less daunting for me to consider!
    Fondy's Avatar
    Fondy is offline spring is here? I hope so...
    Feb 2006
    Fond Du Lac, Wi. Member# 5136
    hey great job on the video. i always wounderd how that was done and now i know.
    thankyou
    :insert sig here
    wquiles is offline LX Newbie
    Dec 2005
    Thanks so much for taking the time to make the video
    Will
    Dodge Charger Top Banana Daytona #450 of 4000
    Electronic Convenience Group, Protection Group, Sirius, UConnect, Sound Group II
    Car went home on Jan 31st, 2006
    Mods: Rear baby car seats (two of them!), Valentine One, Daytona Mats, Trunk Cargo Organizer
    Lost815's Avatar
    Lost815 is offline YEAH...I get all my Tattoos for free....
    Oct 2005
    In the driver's seat with the pedal to the metal!!! Socal transplant in Salem, OR
    shoudn't be a caveman can do it.
    desmo_dude's Avatar
    desmo_dude is offline LX Newbie
    Nov 2005
    Union City, CA
    The local Autozones (called 3 of them) all said that their computers show the Prestone 170 Tstat (pn 983170) has been recalled. They are no longer available. Any idea why? I wonder if it has to do with the fail-open feature. Or maybe it's a regional thing (seeing how it would increase emissions).
    On a side note, I'm still on the fence as to whether I want to do this mod, due to many warning of premature wear of the motor and eventual loss of compression at these cooler temps... maybe I missed it, but what sort of before/after mileage have LX'ers been reporting with the mod?
